mrmichaeljmoore
#1 Posted : Sunday, November 1, 2009 8:50:37 AM(UTC)
mrmichaeljmoore
I have a Kenmore ULTRA WASH dishwasher.
Model # 165.29000
It is about six years old.
The problem we seem to be having is the cycles seem to be running much longer than the time specified in the manual.
For example, I ran a normal wash the other night. Started it about 10pm, just before bed.
I woke up at around 1am and the cycle was still running. It was just a few clicks on the dial before the dry cycle.
According to the manual, the Normal wash should take approximately 98 minutes......
I did read that if the water is not hot enough, the heating element will come on to bring the water back to the required temp of 140 degrees.....and while the heating element is on the cycle timer stops....
My water heater is set at about 120-130 degrees, so I can understand the element needs to come on.....
but would it need to come that much that it would take nearly three hours to run, nt including the dry cycle?
Any ideas on what's the problem here?
Is the heating element bad?
Is there a thermostat that may be bad?
Thanks for the help.
mm
#2 Posted : Monday, November 2, 2009 1:39:53 AM(UTC)
Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%203384557.pdf
Only you can tell, I would just be giving a wild guess.
