My washer is leaking under the tub where the transmission is. It appears to be a bad seal. Is it worth fixing? I have some experience fixing my own washer. Is this something I can do myself? Exactly what parts and/or special tools are required? Any help would be greatly appreciated. Thanks.
Thanks for the help. I'm going to take a shot at fixing it myself.
Good, I think if you are patient and take your time you will be able to do it. Let us know how it turns out.
I finished the repair tonight. Everything seems to be working fine and it's not leaking. There were a lot of steps involved, but none of them were all that difficult. The scariest part was the expensive tools that the directions say you need. They were almost $200. Fortunately I was able to make my own for less than $10. Thanks again for all your help!
Great, and glad you were able to make your own tools as those specialty ones are not all that useful elsewhere.
I thought I would show the tools I made in case anyone else might want to try making them for themselves. I used a scrap piece of 1x4 pine and two 1/4" bolts for the one tool, and 3" PVC cap, a 1'x1/2" threaded rod and some 1/2" nuts and washers for the other. I used a 2" hole saw, a quarter round file, a jig saw, and 1/2" and 1/8" drill bits to make them. It took about an hour to make them both and cost me about $7. jdog attached the following image(s):
Great, you are the second person in the last several days to show us how to make repair tools for Maytag and avoid the huge cost of the specialty tools.
Thanks for sharing that with us. It will be very helpful to a lot of folks.
