trying to replace control module. Have removed the lower front cover. Removed the 4 torx screws at the back of the upper faceplate but am fearful of prying because of stories of broken "tabs". How is it removed? Thx
The instructions are attached to the reply. Gene.
Gene, Thanks for the guidance. Replaced module working as it should
You are welcome. I'm glad you were able to fix it.
