jeremygali
#1 Posted : Saturday, October 24, 2009 8:52:12 AM(UTC)
jeremygali
I have a Whirlpool GU1500XTLS3 that is about 4 years old. The other day the light on top of the normal button started blinking. I pulled the cover off to check if any of the boards were burnt up and everything appears ok. The dishwasher will not do anything. I think it may be the control panel that needs to be replaced. Anyone have any suggestions?
#2 Posted : Sunday, October 25, 2009 4:09:54 AM(UTC)
Could not find info on the given Model Number. The following is for a XTLS3 not a XLTS3
Replacement parts for WHIRLPOOL GU1500XTLS3 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
A single blinking light is often a stuck key. The tech sheet shows how to check this.
jeremygali
#3 Posted : Sunday, October 25, 2009 6:06:13 AM(UTC)
jeremygali
denman, thanks for the help. I checked the diagnostic sequence (high temp, air dry, high temp, air dry) and it did not do anything. The parts link you referenced has a lot of parts. Do I need all of those or just the Panel Cntl? How hard is it to install for a do-it-yourselfer? If I replace this part and it doesn't work can I return it? I don't want to spend $200 on a repair man when a new dishwasher is about $500. Thanks Again!!!
#4 Posted : Sunday, October 25, 2009 8:53:38 AM(UTC)
Yes I figured that would be a long shot but worth a try.
The way this is troubleshot is to check the keypad with meter as shown bottom middle of the first page. This can confirm that you have a stuck key in which case Item 1 Panel cntl needs replacing.
If all the keys check out OK the Item 11 Electronics Control Assembly is the most likely culprit. Still a bit of a crap shoot but your odds are better
Not difficult just take your time taking it apart make notes on anything you feel you may forget. Also the following should help
https://secured.whirlpoo...520548/$FILE/8178022.pdf
No usually if you order electronic parts you own them.
