I Just Changed The Seal And Bearing On My Dryer, Prior To That I Had Some Clothes To Dry But The Drum Would Not Turn. The Dryer Turned On But The Drum Would Not Rotate, So I Changed The Seal And Bearing And It Still Wont Turn, The Belt Looks Somewhat Old. Should The Pulley Be Turning As Well And Which Way Should The Drum Rotate, Clockwise Or Counter Clockwise?
