Hi Everyone,
Moved into a house couple of months ago and it has a "HEIL" Brand natural Gas heater in our home. I've managed to find the following model number(s) on it:
model #GDe075b12a1 mfg# ndn6075f6a1 model# ndn6075fba1 Not sure when it's last been serviced.
it's been acting up lately where it'll be running and then all of a sudden basically blow cold air. When I go to look at it, the pilot light is lit, but the burners don't come on, but the blower is running (and usually keeps running!).
If I turn off the power to the furnace i see the following 2 things happening a) If I do a quick 'off-on' the pilot comes back on, but no ignition of the burners b) if I leave it off for a little bit longer then the burners usually come on. There's 1 'rollout switch?' (is that what they're called?) up front, but it hasn't popped.
So I'm not sure if the problem is that a) the blower keeps running or b) that the burners come on or if they're related somehow, but either way with the cold weather coming it needs to be fixed asap! so any suggestions on what to look for and/or what i can do myself would be much appreciated!
Thank you
