sunlake
#1 Posted : Monday, October 19, 2009 12:54:21 PM(UTC)
sunlake
My dishwasher is pumping the water out before the wash cycle.
My dishwasher set to normal wash runs water into the machine and then starts the pump and drains the dishwasher. The dishwasher make a sound as if it is washing but with no water. During the cycle water runs in again and the pump drains it again. The dishes are not getting washed because no water is staying in the machine. I need help to identify my problem.
#2 Posted : Tuesday, October 20, 2009 3:04:35 AM(UTC)
Replacement parts for GE GSD5130D00WW | AppliancePartsPros.com
Remove the kick plate.
On the left hand side of the motor assembly you will see a solenoid.
Check that it is in the up position.
If it is up but is pulled down when you start a cycle then you have other problems.
This solenoid is connected to a flapper valve in the housing. The flapper directs the water up to the spray arms (piston up) or out the drain (piston down).
Could be it is stuck in the down position perhaps a spring has come off etc.
You may have to remove and inspect it. If it has overheated and melted the plastic then you may have other problems with the unit.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
