eighead
#1 Posted : Sunday, October 18, 2009 6:07:07 AM(UTC)
eighead
How do you get to the pump filter?
#2 Posted : Monday, October 19, 2009 4:22:11 AM(UTC)
Here is a service manual which should help, the pumps look the same.
http://www.servicematters.com/m...ibrary/docs/16010622.pdf
eighead
#3 Posted : Monday, October 19, 2009 4:31:04 AM(UTC)
eighead
Thank you. I will review.
eighead
#4 Posted : Monday, October 19, 2009 5:25:45 AM(UTC)
eighead
Read it, got the spray arm and cover off and found plastic had fouled the sprayer arm and the (dont see the nomenclature for it) four armed thing behind the filter. Pump filter was in good shape. Cleaned both and its working like a champ. Thank you much.
eighead
#5 Posted : Monday, October 19, 2009 5:28:47 AM(UTC)
eighead
Just the ticket for, what turned out to be a simple fix. Just needed to figure out how to get under the spray arm. The generic repair manual did the trick. Thanks to Denman and this website. I am now a big fan.
Ken
