Hello. I ordered and recieved a replacment oven controller and it has additional terminals beyond the original. The original part (# WB27K5334) has board mounted relays with only the output terminal connections showing for Conv, Bake, and Broil. The new replacment controller (# WB27T0204) has the three board mounted relays also, but with all relay contact points available. Convection relay has a Com and N/O Bake and Broil, both have a Com, N/O , & N/C Do I need to jumper L1 to all three relay coms? Also, I would assume that the N/O connection is used on bake and broil w/ the N/C connection left empty. Is that correct?
Thanks, J. Miller
