Chris1215
#1 Posted : Saturday, October 17, 2009 7:30:34 PM(UTC)
Chris1215
The agitator doesnt move during any cycle enough to wash. However it does move slightly enough to see. Please help.
applianceman
#2 Posted : Saturday, October 17, 2009 7:53:59 PM(UTC)
applianceman
Reach in and try to turn the agitator by hand and if you can the agitator coupling is bad. Pull the agitator straight up and out once done you should see the agitator coupling try turning it by hand and if it will turn you have confirmed the coupling is bad, replace it. Clothes Washer Repair Guide
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Speed Queen top load washer model AWN412SP111TW01 (Washer Repair)
by Guest 4/28/2024 6:36:53 PM(UTC)
Samsung top load washer won’t start (Washer Repair)
by aw2055989 4/19/2024 4:42:33 AM(UTC)
Speed Queen top load washer model AWNE82SP113TW01 (Washer Repair)
by Guest 2/2/2024 10:12:50 AM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
Speed Queen top load washer modelAWN542SP111TW01 (Washer Repair)
by Guest 1/27/2024 10:43:32 AM(UTC)
Speed Queen top load washer model AWN542SP111TW01 (Washer Repair)
by Guest 1/13/2024 1:28:32 AM(UTC)
Speed Queen top load washer (Washer Repair)
by Guest 12/23/2023 3:02:14 AM(UTC)
Speed Queen top load washer typical model AWNE82SP113 (Dryer Repair)
by Guest 12/1/2023 8:26:13 AM(UTC)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Speed Queen top load washer model AWS17NW (Washer Repair)
by Guest 10/16/2023 11:23:35 AM(UTC)
