THINGUYEN
#1 Posted : Friday, October 16, 2009 1:40:15 PM(UTC)
THINGUYEN
Help!!! My dishwasher had not been run fro a few weeks and when we ran it we got a burning smell (like burnt plastic or wiring smell) coming from the wash chamber. I opened the kick panel underneath and there is not smell or burnt components down there, and the pump runs fine. The heating coil does not have any fallen plastic or anything on it, but the coating on the element seems to be coming off (looks like rust) when I rub it. Do I need to replace the heater coil? Is there anything else I should check first?
#2 Posted : Saturday, October 17, 2009 4:04:17 AM(UTC)
Replacement parts for WHIRLPOOL DU840SWLT0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208051695.pdf
I would disconnect one wire from the heating element.
Tape it up so it cannot short to anything.
Then run a couple cycles, just to ensure that something else is not the problem.
