BBlack5
#1 Posted : Thursday, October 15, 2009 3:26:45 PM(UTC)
BBlack5
I have had this dishwasher for 2 1/2 years and now has broken for the second time. Once at 1 1/2 years, of course out of warranty. The soap door would not open at that point, now the "Normal" button will not work. The other buttons seem to work but the dishwasher just shuts off after a minute or so. Any ideas?
#2 Posted : Friday, October 16, 2009 3:13:58 AM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL KUDK02CRBS3 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...heet%20-%20W10082651.pdf
The Normal key not working could be just the keypad.
The tech sheet show how to check it with a meter.
Try the connector cleaning shown below.
The stopping during the cycle on the other cycle options is more perplexing.
Sounds like the unit is waiting for a signal input and either is not receiving it or interpreting it incorrectly.
Try running the diagnostics to narrow it down.
Connector Cleaning
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
BBlack5
#3 Posted : Saturday, October 17, 2009 6:20:50 AM(UTC)
BBlack5
Thanks. Funny thing is.....after looking at all the dishes I had to do. I tried the dishwasher and it worked just fine this morning. I am not sure what is going on.
#4 Posted : Saturday, October 17, 2009 7:51:25 AM(UTC)
This does sound like a dirty contact/connector often this will cause an intermittent problem.
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
