NEED HELP77079
#1 Posted : Monday, October 12, 2009 11:41:49 AM(UTC)
NEED HELP77079
Diswasher only displays Quick clean up cycle and Energy saver dry. cannot change cycles or dry modes. 4 hour delay seems to still work. Any suggestions?
csager
#2 Posted : Monday, October 12, 2009 5:30:18 PM(UTC)
csager
Other posts have noted similar problems with the control panel the control lock is activated. If so hold air dry down for 5 - 10 seconds to release the lock.
NEED HELP77079
#3 Posted : Monday, October 12, 2009 6:11:04 PM(UTC)
NEED HELP77079
Control lock works fine. Tried multiple times to switch cycles but no luck.
#4 Posted : Wednesday, October 14, 2009 2:16:26 PM(UTC)
Replacement parts for WHIRLPOOL KUDS01DLSS0 | AppliancePartsPros.com
Here is the tech sheet run the diagnostics.
http://www.servicematters.com/d...0Sheet%20-%208533399.pdf
Clean the connections as shown below.
Check the keyboard with a meter. If the keyboard checks out OK then the control board comes to the top of the list as the cause.
Connector Cleaning
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
NEED HELP77079
#5 Posted : Wednesday, October 14, 2009 3:08:30 PM(UTC)
NEED HELP77079
Thanks for the tech sheet, I will try to use it and your advise this weekend. Thanks once again!
#6 Posted : Wednesday, October 14, 2009 5:07:49 PM(UTC)
You are welcome
Please let us know how it goes.
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Mah2400aww Maytag Door Boot Door Diaphragm Discontinued, Help! (Washer Repair)
by DIY_Vee 3/4/2022 7:34:13 AM(UTC)
Ice maker dispenser will not stop running - help! (Refrigerator & Freezer Repair)
by Guest 1/30/2022 7:11:17 PM(UTC)
Maytag Bravos MCT HELP!!!!! (Washer Repair)
by Guest 10/23/2021 7:31:14 AM(UTC)
Help! Does motor need to be replaced or cleaned out? (Dishwasher Repair)
by connellh 4/30/2021 8:36:32 AM(UTC)
Kenmore not cooling - Can't get a replacement fridge HELP! :) (Refrigerator & Freezer Repair)
by shorton 11/9/2020 11:33:04 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
