tony chang
#1 Posted : Friday, October 9, 2009 6:13:51 PM(UTC)
tony chang
Dear sir: I have a whirlpool quiet partner ll,model du1100xtps1 about 5 yrs old.It current works only on drain&cancel setting.The " normal" mode selection buttom and the "star" buttom are unresponsive.can you suggest the control panel or control board is bad? Thank you!:confused:
#2 Posted : Saturday, October 10, 2009 4:38:26 AM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL DU1100XTPS1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208535451.pdf
Do not know what button is the "star" button but if it is the start button, you will notice in the tech sheet that the start and normal buttons have P1-4 as a common.
I would check the keyboard as outlined in the tech sheet.
The normal way to trouble shoot is check the keypad if it is OK then replace the control board. Note this is still a bit of a crap shoot but it does give you better odds of ordering the correct part.
Try the following first.
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
