maverickfe
#1 Posted : Sunday, October 4, 2009 9:57:32 AM(UTC)
maverickfe
HI I have a Kenmore Elite 665.1593900 and the trouble with it is I have no heat does not clean and does not dry on heat. Use too when I open the door it I would get hit but the steam but nothing now. And does anyone have a TROUBLESHOOT MANUAL for this model.
#2 Posted : Monday, October 5, 2009 3:27:05 AM(UTC)
Here is your tech sheet.
http://www.servicematters.com/d...0Sheet%20-%208524517.pdf
Check the heater and the hi-limit thermostat for resistance/continuity with a meter.
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
No hot water (Washer Repair)
by scv1 12/29/2015 7:41:39 PM(UTC)
by scv1 12/29/2015 7:39:54 PM(UTC)
No Hot Water Coming From Inlet Valve (Washer Repair)
by sophialh74 10/17/2014 5:37:11 AM(UTC)
No hot water in Maytag washer (Washer Repair)
by Pastaronie 8/16/2014 12:29:47 PM(UTC)
by arylisrandy 10/20/2013 1:35:09 PM(UTC)
No Hot Water in Washer (Washer Repair)
by Obuasi 2/8/2013 4:30:18 AM(UTC)
No Hot water (Washer Repair)
by jeschw 8/5/2012 6:19:05 AM(UTC)
No Hot Water Coming Into Washer (Washer Repair)
by chloed 2/7/2012 8:08:03 AM(UTC)
by lindaa 12/8/2011 3:39:17 PM(UTC)
maytag washer no hot water (Washer Repair)
by lindaa 12/7/2011 11:18:26 AM(UTC)
Whirlpool dishwasher has no hot water or heat for drying (Dishwasher Repair)
by ford2953 6/27/2011 5:10:33 PM(UTC)
Whirlpool Washer - No Hot Water (Washer Repair)
by jeff mitchell 5/20/2011 8:43:32 PM(UTC)
by amayesin 4/30/2011 4:03:38 AM(UTC)
Frigidaire Washer - No Hot Water (Washer Repair)
by cdWJordan 4/8/2011 12:52:49 PM(UTC)
