catmorgn
#1 Posted : Wednesday, September 16, 2009 7:29:18 AM(UTC)
catmorgn
Last night the washer stopped spinning.. it goes thru all the cycles- fills and drains. but the basket doesnt move.. therefore the clothes are very very wet.
Machine is more than 10 yrs old. Never have had a service call on it. Is this an inexpensive fix or should I start looking for new machine? I dont have problem fixing machine- if the cost will be quite a bit less than new machine.. Any suggestions?
applianceman
#2 Posted : Wednesday, September 16, 2009 10:41:59 AM(UTC)
applianceman
Kenmore appliances are made by lots of companies need model number to know that you have. Clothes Washer Repair Guide
catmorgn
#3 Posted: : Wednesday, September 16, 2009 10:53:16 AM(UTC)
catmorgn
It says Kenmore- Heavy Duty 60 Series.. I bought it at Sears. I will have to go home to check more... dont know if this helps
applianceman
#4 Posted : Wednesday, September 16, 2009 4:02:21 PM(UTC)
applianceman
Well Whirlpool makes most Kenmore washers but I hate to answer about Whirlpool and it turns out to be something else. We always need the model number especially on Kenmore. The model number should be near or in the lid.
catmorgn
#5 Posted : Thursday, September 17, 2009 6:43:10 AM(UTC)
catmorgn
Ok,
I found the model etc.. it said Model # 110. 92260100
Serial # CC0221372
Does that help?
applianceman
#6 Posted : Thursday, September 17, 2009 8:40:50 AM(UTC)
applianceman
Ok it is made by whirlpool. The coupling is most likely broken this page will describe how to remove the motor http://www.appliance-repair-it.com/Whirlpool-washer-disassembly.html Once the motor is removed you can access the coupling.
