My freezer was not cooling properly so I replaced the defroster bulbs. The problem seems fixed as my freezer was 0 degree and my fridge was around 38 degrees. Now the freezer seems to have water running down the coils and freezing up at the bottom of freezer. checked flow to pan underneath and was no clogg. my icemaker quit working a few months ago. Could water from icemaker be the problem? I put the arm up on the icemaker and freezer fan shut off. PLEASE HELP ME!!!!!!!!!!!!:confused:
:confused: Originally Posted by: rmarryman My freezer was not cooling properly so I replaced the defroster bulbs. The problem seems fixed as my freezer was 0 degree and my fridge was around 38 degrees. Now the freezer seems to have water running down the coils and freezing up at the bottom of freezer. checked flow to pan underneath and was no clogg. my icemaker quit working a few months ago. Could water from icemaker be the problem? I put the arm up on the icemaker and freezer fan shut off. PLEASE HELP ME!!!!!!!!!!!!:confused:
