ALMART67
#1 Posted : Tuesday, September 15, 2009 9:18:34 PM(UTC)
ALMART67
Freezer Is Icing Over. If I Unplug It, It Defrosts. Then I Replug It. It Works About A Week Then Ices Again. I Have Completed This Process 3 Times And It Has Done The Same Thing 3 Times.
#2 Posted : Wednesday, September 16, 2009 2:20:52 AM(UTC)
Without a model number cannot give specific info but you have a defrost problem.
Can be one of 3 components.
1. The defrost heater is blown.
2. The defrost thermostat is open.
2. The defrost timer is not working. Some units use a mechanical type timer, some units have a separate adaptive defrost board and some units have the defrost controlled by the main circuit board.
Below area couple good site witch should help you troubleshoot
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
