Hello, my refrigerator does not dispense water or ice from the door. The water reservoir is NOT filling, NO lines are frozen, the ice maker IS working as I tested it by filling the cube slots and the ice popped out a couple of hours later. The water supply to the refrigerator IS hooked up properly, and the water valve as the wall IS open. The filter has been removed and a bypass cap put in its place. When I press for water I do hear a low sound, but am not sure what it is. When I press for ice the auger does work. Any advice on what might be wrong? please email me with any feedback apoch20@hotmail.comThanks
usually there are two solinoids one for water and one for the ice maker. Check and then replace the ice maker solinoid if it's bad?
I have located the solenoid valve. It is one device, with two flow outlets, one to the door for water, one to the ice maker.
How can I determine if the valve is bad?
You'll need to power it from the another source. Since this is often difficult for an amateur repairman, it is often easier just to substitute.
How about testing it with a Multi meter? will that be effective?
Yes, it should be. An open circuit means an open winding.
