buck24
#1 Posted : Sunday, September 13, 2009 2:01:27 PM(UTC)
buck24
my washer will not spin after inital fill. motor is very warm. i was able to force into spin cycle 1-2 times. not sure what the problem is. does anybody have any idea
#2 Posted : Monday, September 14, 2009 1:42:50 PM(UTC)
Does it make any noise?
buck24
#3 Posted : Monday, September 14, 2009 2:15:38 PM(UTC)
buck24
Gene, it makes a very loud noise when it hits spin cycle. The motor gets very hot after it cools down or has no weight in it, it works fine until it heats up.
#4 Posted : Monday, September 14, 2009 4:54:16 PM(UTC)
Tilt the washer back, remove the belt and check how freely the pump is moving in both directions.
- The pump Part number: AP4373022
Here are the breakdown diagrams for the Amana washer Model NAV2335AWW
