wshepher
#1 Posted : Sunday, July 19, 2009 9:46:38 AM(UTC)
wshepher
Compressor quits from time to time. Found that if I unplug fridge problem re-sets only to occur again within 24-48 hours. Research shows no defrost timer on unit? Any help?:)
#2 Posted : Sunday, July 19, 2009 4:04:35 PM(UTC)
You have the unit with the motherboard in the back. If you can solder, pull the cover off, remove the board (has 4 nylon pins to squeeze off) and check for burnt solder connection at one of the power relays. If so, just resolder with rosin core solder.Be carefull, but use enough solder to cover the pin all the way around.
wshepher
#3 Posted : Sunday, September 13, 2009 7:44:50 AM(UTC)
wshepher
Thanks for your help! It worked fine for about a month? Now I have replaced thermostat, re-soldered the relays and it is acting crazy. It goes out on defrost ( I think) then starts clicking on the mother board about every 1.5 seconds and definately has a voltage drop because the lights dim with each click. Sometimes it comes out after an hour or so of clicking but last night it went down for six hours and we lost food. I hate to spend another dime on this unit especially a mother board. Sounds like a contactor trying to pull in but not latching. Any ideas, guesses, suggestions, beer would be appreciated.. Thanks, Bill
#4 Posted : Sunday, September 13, 2009 8:05:20 AM(UTC)
Your compressor may be going sour. Unless you have a meter, I would get it looked at by a pro.
Either that, or check what the board is doing. I have seen these boards turn the defrost heater and compressor on at the same time. You just might have a solder short on the board.
Unplugged oven (Oven Repair (including Ranges and Cooktops))
by Christaschutte 2/4/2020 5:01:19 PM(UTC)
Whirlpool oven won't ignite unless unplugged and plugged back in. Thoughts? (Oven Repair (including Ranges and Cooktops))
by wbynum 12/20/2018 7:31:13 AM(UTC)
GAS dryer stays very HOT even when unplugged (Dryer Repair)
by Msmommypants 1/14/2018 9:09:03 AM(UTC)
Washer only spins, and has to be unplugged to stop. (Washer Repair)
by metalheadbrian 5/16/2017 5:49:13 AM(UTC)
How long do I leave unplugged? (Refrigerator & Freezer Repair)
by MandyC 6/26/2014 11:49:55 AM(UTC)
220 plug sparked when unplugged (Dryer Repair)
by fstop61 9/29/2013 12:12:57 PM(UTC)
Bosh dishwasher makes noise unplugged (Dishwasher Repair)
by Gabor_in_AA 9/19/2013 5:11:13 AM(UTC)
Refrigerator Stops And Will Work If It Is Unplugged And Plugged Back In After 5 Min. (Refrigerator & Freezer Repair)
by joebrandom 12/9/2012 3:12:39 PM(UTC)
freezer sat unplugged now wont cool (Refrigerator & Freezer Repair)
by tsonny 7/11/2012 3:43:58 PM(UTC)
Left frig unplugged for 1 yr and now won't cool (Refrigerator & Freezer Repair)
by LAGalicia8 5/20/2012 3:05:09 PM(UTC)
Frigidaire FRS26R4AW6 stops cooling, starts cooling after unplugged. (Refrigerator & Freezer Repair)
by ckdorsey 10/31/2011 5:27:20 PM(UTC)
element continues to heat after timer goes to off until unit is unplugged. (Dryer Repair)
by 123blake 1/29/2011 9:14:50 AM(UTC)
water dispenser switch stops compressor until ti gets unplugged (Refrigerator & Freezer Repair)
by willsawa 1/6/2011 2:24:01 PM(UTC)
whirlpool ref won't run unless unplugged for 5 mins. (Refrigerator & Freezer Repair)
by tippywanknobi 7/2/2010 1:00:24 PM(UTC)
KitchenAid - Frig cooling only when Diffuser unplugged - Any Suggestions? (Refrigerator & Freezer Repair)
by rdelaune 2/3/2010 12:25:24 PM(UTC)
