Control Panel Relay went out on the upper oven. I can turn it on but it will not shut off when i hit the Cancel button. I really can't afford to replace the entire board. Last time it went out it was still under warenty. I have a degree in electronics and can replace components on the board. Can i just purchase the relay switch somewhere by itself?
All relays K4 thru 10 have 150 ohms across them except K7 which only has 72 ohms the relay number is 832A-1C-F-C
K3 has 400 Ohms across while K1 and K2 have 75 ohms. Relay number is 899B-1C-F-C E1
