Fridge is warm, condenser kicks on only for 20 sec. at a time. The fan for coils run all the time. Whats wrong with it?
Originally Posted by: boatnsme  Fridge is warm, condenser kicks on only for 20 sec. at a time. The fan for coils run all the time. Whats wrong with it? If the condenser fan is running and the compressor is trying to start but not doing so successfully, that is usually a sign of the compressor being bad. Although, it could also be a issue with the relay, or overload which assist with the starting of the compressor.
