Keli
#1 Posted : Wednesday, September 9, 2009 3:32:01 AM(UTC)
Keli
In May,repaiman replaced the relay.Was fine for a while then started thawing again. Was advised it could be the defrost timer. Ordered and installed timer-was fine, then five days ago everything was completely thawed overnight. Turned setting up to 3-has been fine again-but I know it's going to happen again.Any ideas?? Thanks
#2 Posted : Wednesday, September 9, 2009 3:41:00 AM(UTC)
Need more info. What was not running when it failed. You seem to imply just turning up the cold control fixed it!
Keli
#3 Posted : Wednesday, September 9, 2009 3:52:24 AM(UTC)
Keli
The whole refrigerator/freezer stopped running.Installed defrost timer,was ok for a while-then everything thawed again.Turned sttine up, worked again. It's been doing this since May.
#4 Posted : Wednesday, September 9, 2009 4:57:25 AM(UTC)
Next time it fails, tap on the control panel, if it then turns on, you probably have an intermittent cold control or connector.
Freezer troubles..... (Refrigerator & Freezer Repair)
by AviF 1/19/2014 6:39:53 AM(UTC)
Amana freezer troubles (Refrigerator & Freezer Repair)
by Tolbear 5/30/2010 8:13:40 AM(UTC)
