waltonml
#1 Posted : Tuesday, September 8, 2009 12:08:41 PM(UTC)
waltonml
It won't go into the defrost cycle and has to be manually defrosted every couple of weeks. Appliance Rescue came out and said it was the thermostat in the freezer and replaced it but we are having the same problem.
Thanx
applianceman
#2 Posted : Tuesday, September 8, 2009 3:03:36 PM(UTC)
applianceman
The defrost heater causes this most of the time but I would assume they checked that. If the heater is ok the only thing left is the main board. Refrigerator repair guide
#3 Posted : Wednesday, September 9, 2009 2:41:33 AM(UTC)
Unplug refrigerator, remove the motherboard cover in the back of fridg. and remove the three pin power connector. Compare the connector pins with the ones labled defr. and line/L1. Put a jumper between the mating pins on the connector. Fridg should now defrost, if so, replace the motherboard and evaporator thermister clipped to the evaporator coil in the freezer. You can look up the part #s on this site.
GSH25JFXB defrost runs too long (Refrigerator & Freezer Repair)
by Guest 7/2/2024 8:29:10 PM(UTC)
Frigidaire FFHT1835VB1 Stuck in Defrost Mode (Refrigerator & Freezer Repair)
by dcuozzo 5/6/2024 9:55:29 AM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
SAMSUNG RF26J7500SR/AA - defrost heater testing (Refrigerator & Freezer Repair)
by curious99 3/30/2023 12:50:23 AM(UTC)
Not defrosting and motor/compressor running constantly (Refrigerator & Freezer Repair)
by egizzi 3/23/2023 7:05:21 PM(UTC)
Refrigerator manual defrost (Refrigerator & Freezer Repair)
by Retired8291 2/7/2023 2:08:02 PM(UTC)
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 12/18/2022 11:23:17 AM(UTC)
How to start manual defrost 18yr old kitchen air refrigerator (Refrigerator & Freezer Repair)
by brianappj 11/17/2022 7:47:58 AM(UTC)
defrost heater not working but testing fine on multimeter (Refrigerator & Freezer Repair)
by doland 10/23/2022 11:10:02 PM(UTC)
Samsung Bottom Freezer Refrigerator Defrost Heater Replacement Part Help (Refrigerator & Freezer Repair)
by treefort 10/15/2022 11:51:27 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
Replacing the defrost heater, one bulb or two bulb heater? (Refrigerator & Freezer Repair)
by emilclintoc 7/12/2022 8:36:58 AM(UTC)
GE freezer keeps having to be defrosted (Refrigerator & Freezer Repair)
by Guest 4/7/2022 11:46:37 AM(UTC)
Defrost heater for very old Sears Coldspot 106.7627410 (Refrigerator & Freezer Repair)
by kboyette 3/20/2022 3:31:17 PM(UTC)
samsung rs261mdrs freezer defrost troubleshooting (Refrigerator & Freezer Repair)
by erkj79 2/13/2022 12:13:58 PM(UTC)
