thomashaskins
#1 Posted : Friday, September 4, 2009 11:58:49 AM(UTC)
thomashaskins
First is was leaking from bottom of fridge. Now it just will not cool enough. Getting worse fast. Freezer was icing up too. It was leaking and cold for 2 or 3 months before it stopped cooling. Please help. Thank you.
#2 Posted : Friday, September 4, 2009 2:20:33 PM(UTC)
Remove the cover on the back of the refrigerator. Make sure the compressor and the fan next to it are working and the condenser is clean.
Remove the rear panel in the freezer and check how the evaporator is covered with snow and is the fan working.
Post the results.
Here are the breakdown diagrams and Replacement parts for GE TFH22PRSMWW | AppliancePartsPros.com
thomashaskins
#3 Posted : Tuesday, September 8, 2009 10:03:37 AM(UTC)
thomashaskins
Thank you Gene for your reply. I work 80 hours/week so I will not be able to try the immediately. However, in the mean time, here is a little more info:
When I unplug it and let everything melt and then plug it back in again, it cools properly for a few days and then it begins it decline again. Does that help narrow it down at all?
Thank you.
#4 Posted : Sunday, September 13, 2009 6:01:14 PM(UTC)
Can be a problem with the defrost system.
