2 Pages12>
tbest661
#1 Posted : Friday, September 4, 2009 10:41:19 AM(UTC)
tbest661
:confused: Ice Maker and Water Dispenser not working. I replaced the dual refrigerator water valve. Control panel works. Why isn't the water getting to the ice maker and to the dispenser? If I put ice in the bin, the dispenser works. The refrigerator sat for about a year without being used. I plugged it back in...ice maker and water dispenser not working. Can you help? TroubledTerry
#2 Posted : Friday, September 4, 2009 12:30:38 PM(UTC)
How old is a water filter, if there is one?
How good is the incoming water pressure?
tbest661
#3 Posted : Friday, September 4, 2009 12:32:38 PM(UTC)
tbest661
No water filter that I can find...none in the refrig...none on the back...none on the bottom. Incoming water pressure is REAL GOOD!
tbest661
#4 Posted : Friday, September 4, 2009 12:33:41 PM(UTC)
tbest661
don't know if I am posting to you or not...
water pressure is real good...can't find a filter ANYWHERE
#5 Posted : Friday, September 4, 2009 12:45:01 PM(UTC)
Double check the water valve installation.
Locate the solenoid on the water valve for the water dispenser (5/16" plastic tube). Remove the wires and check for 120 VAC between them while the water dispenser calls for water.
tbest661
#6 Posted : Friday, September 4, 2009 12:56:07 PM(UTC)
tbest661
Okay...I'll try
tbest661
#7 Posted : Friday, September 4, 2009 12:58:49 PM(UTC)
tbest661
Husband too busy to do this right now:mad: (mowing the dead grass), can I have him call you later?
#8 Posted : Friday, September 4, 2009 1:04:02 PM(UTC)
Just let him to run this test and post the results.
tbest661
#9 Posted : Friday, September 4, 2009 1:04:59 PM(UTC)
tbest661
OKAY...may be tomorrow...thanks.:)
mlbmlb
#10 Posted : Friday, September 4, 2009 7:00:31 PM(UTC)
mlbmlb
I am getting H2o to icemaker. but not to the door.
pulled access panel getting 120v to both blue solinoids when pressing the "gimme some water darnit" button.
checked resistance 328 on both blue solonoids, and 183 on both reds ( ice maker valves)
I musta done something wrong- caue if one of the blue solonoid is bad i would think I would get a differnet resistance?
Any other suggestions???
thasnks in advance
Guest (10)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Ice maker and water dispenser intermittently working (Refrigerator & Freezer Repair)
by Pacochu 2/16/2014 1:38:27 PM(UTC)
Kenmore ice maker and water dispenser (Refrigerator & Freezer Repair)
by zhubbard 7/16/2009 9:57:30 AM(UTC)
Ice Maker and Water dispenser are parched (Refrigerator & Freezer Repair)
by konfuzed 4/28/2008 11:43:48 AM(UTC)
2 Pages12>
