mano39
#1 Posted : Tuesday, September 1, 2009 12:57:26 PM(UTC)
mano39
I have to replace the water inlet valve on this fridge. I am having difficulty in removing the flex tubing from the existing valve. The tubing looks like just pushed in the coupling.
Any help will be appreciated
applianceman
#2 Posted : Tuesday, September 1, 2009 2:27:51 PM(UTC)
applianceman
Yes most of them are pushed in now. On the valve there is a white ring where the tube is pressed in. Press in on the ring and pull out on the tube at the same time. Refrigerator repair guide
