no water at door.food in chrisper froozen
The model number you posted does not come up. Verify and repost it.
Can you be more specific on the problem?
Originally Posted by: Gene  The model number you posted does not come up. Verify and repost it.
Gene. it is a (profile arctica mod#pss25mgna bb . ser. #gd426639 )refer. is freezeing . temp. is 20 to 25 food freezeing lower part of box.
Very likely the damper (#420 on the diagram) is stuck open. This very common problem with Arctica refrigerators. The correction is to replace the damper assembly. - The damper assembly Part number: AP3775595
Originally Posted by: Gene  Very likely the damper (#420 on the diagram) is stuck open. This very common problem with Arctica refrigerators. The correction is to replace the damper assembly. - The damper assembly Part number: AP3775595
thanks for help !!!
