Iownagn-gs
#1 Posted : Tuesday, August 25, 2009 10:18:35 AM(UTC)
Iownagn-gs
I just purchased from you defrost thermo, defrost heater and installed yesterday. Re-installed the ice maker. Maker fills, freezes, harvests but the cancel linkage will not go back down to start the cycle again. Could I have not pushed the connector in hard enough? Was working normally before, I guess they all do>:)
Frank / APP Team
#2 Posted : Tuesday, August 25, 2009 10:43:48 AM(UTC)
Frank / APP Team
When the sensor arm is down and you lift it a little bit does it drop back down on its own?
Not real sure what you mean by the connector not being pushed in hard enough. If the IM is functioning, it wouldn't be a connection from a electrical standpoint. Need to see if the arm is binding for some reason.
Double check your work, shouldn't really be a connection between what you did and what you're describing about the IM.
ice maker down send help (Refrigerator & Freezer Repair)
by mechman 8/23/2008 8:12:49 AM(UTC)
