This is a side by side with an icemaker in the freezer section. The problem is the freezer section is cold but not cold enough. Raising the termostat has no effect. The refrigerator section is OK, I believe. I believe the problem started after I vacuumed under the refrigerator.
Had a power outage to area due to a lightning strike. Compressor feels hot. Unplugged unit and replugged in Compressor runs for 5 seconds and shuts off. Compressor runs again intermittly for only 5 seconds and shuts off again.
Fixed!! Bad Overload Relay:)
