Washer spin speed too slow
[quote=richappy;117470]I would shine a light in the spin basket to look for something stuck in the tub.
If ok, you might have bad spin bearings, pull front cover and check.[/quote]
nothing stuck in tub. I pulled front panel all I see is the motor, pump and Agitator shaft which is a sealed unit which must be connected to the main pully. Nothing smoking or hot on unit.:confused:
wes
