Washer will not agitate in all wash cycles but will work in rinse/spin cycle. When a wash cycle is selected the washer fills timer advances in the wash cycle but does not agitate. As the timer advances a clicking noise is heard. When it reaches the rinse cycle the agitator works works fine. Also spin mode works fine. This happened after I changed the belt and had a look at the timer. I did not remove or do anything to the timer.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
You did something wrong. Maybe a timer pin came out on the connector. Rather rare these timers go bad, but it seems like a timer issue. Also, do you have a speed control switch on the panel?
Thanks for your help. Yes their is a Wash/Spin speed select knob on the panel. The reason I change the belt was the washer spin was leaving the clothes to wet and I thought the belt may be slipping. The spin speed seems to be at the same seed in all cycles. Could this be the problem. I did not see connector pins or anything else loose. Before I pay eighty bucks for a new timer do you think I should try a new Washer/Spin switch.:mad: Wes
Rare these plastic timers go bad.The speed switch is supplying low and high speed current to the motor at the same time, just replace it. You can ohm it out per the schematic if you have a meter.
Originally Posted by: richappy Rare these plastic timers go bad.The speed switch is supplying low and high speed current to the motor at the same time, just replace it. You can ohm it out per the schematic if you have a meter.[/quote. :)
Thank you again. I replaced the Timer and the Washer Agitator problem was solved, However in the wash mode sometimes it makes a knocking sound as if a shoe or something is in the tub, but I lift the lid and stop the wash and then close the lid , the knock goes away. I inspected the load can not find anything except water and clothes. It goes ok and may or may not knock again for a while. Last but not least the clothes sill are more wet than they should be. Maybe the wash spin switch needs replacing also. Your opinion would be appreciated.
Wes
If the agitator spins at the same speed in gentle or normal cycles, your speed switch is probably bad.
