Whirlpool Washer Water Overfills
[FONT=Times New Roman][SIZE=3][COLOR=#000000]If you cut the washer off and the water stops take Prof. Maneuver’s advice but if you cut off the washer and water continues to run replace the water inlet valve. Washer Repair Guide[/COLOR][/SIZE][/FONT]
