Whirlpool Washer Water Overfills
Kmartin-
My guess would be this http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3019752&&model_id=257418&diagram_id=85069
This is what tells the electrical system to shut off the water valves. Could be the switch itself or a break in the tube that feeds it the pressure signal. No pressure signal from a breached tube means “I’m not full yet, keep filling”.
Best of Luck to You,
Steve
