mikail
#1 Posted : Monday, June 29, 2009 5:50:08 PM(UTC)
mikail
:)washing machine goes through complete washing cycle but does not agitate or spin.....water does drain ok
applianceman
#2 Posted : Tuesday, June 30, 2009 2:42:52 PM(UTC)
applianceman
The motor coupling is the most likely cause. At times it will brake or strip out causing this problem. You must take the motor off to check it this page will help with that Whirlpool Washer Disassembly Guide
GE washing machine does not agitate or spin (Washer Repair)
by SandieS 3/25/2013 4:11:01 PM(UTC)
by mikail 6/29/2009 5:46:05 PM(UTC)
