Ice maker not working. Water dispenses fine. Replaced filter. model is GE ESL25XGPC BS. Electronic maker. LED stays on, does not blink. Doesn't appear that water is coming down to ice maker.
Does any one have an idea about trouble shooting? I have the maker out of the fridge and the open to the circuit board.
Dave
Turn the icemaker off then reinstall it. Turn it back on and within 15 seconds press the little flat arm in three times. If done correctly the icemaker should go through the cycle and run water. If it doesn’t run water more than likely the water valve is bad. But it could still be the icemaker not sending voltage to the valve. For more on this visit GE Icemaker Repair Guide
Thank you very much for the tip on troubleshooting!! Ice maker seems to be working well now. Hopefully it continues for years to come. Saved me a bunch of money in repair costs!! Thank you, Thank you, Thank you.
Dave
