My washing machine allows the water to drain out the drain hose while it is filling so it never fills.
Your drain hose is probably creating a siphon action be either being too low in the drain pipe, or you have sealed off the spot where the drain hose connects to the drain pipe and air cannot get in.
Fix this and you should be all set.
