Discuss
Washer overflows when set at large load
 in
Washer Repair
Hi, My Maytag (13 years) overflows when the water level is set above small. With the water level set above
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer overflows when set at large load
  #1 (permalink)
Old 06-07-2010, 11:46 AM
Junior Member
Victor Scott is on a distinguished road
Default Washer overflows when set at large load
Model Number: LAT4916AAE   Brand: Maytag   Age: More than 10 years
My Maytag (13 years) overflows when the water level is set above small. With the water level set above small, sometimes water flows over the basket and down the sides. When the level is set at Large of Super, the water will not stop flowing. If I press down on the agitator, the water stops.
I'm wondering if this is related to a defective water switch...
I've called a repair person (I'm in Brazil) and he thinks it's the water switch.
I read about a similar problem in this forum about a GE washer. The advice given was to verify the hose running from the water switch to basket bottom-- it might be clogged or with leaky...
Thanks for any help you might provide me with!
Victor
Related Models
Maytag LAT4916AAE WASHER-TOP LOADING
Maytag LAT4916AAM WASHER-TOP LOADING
Maytag LAT4916ABE WASHER-TOP LOADING
Maytag LAT5000AAL WASHER-TOP LOADING
Maytag LAT5000AAW WASHER-TOP LOADING
Maytag LAT5000ABL WASHER-TOP LOADING
Maytag LAT5000ABW WASHER-TOP LOADING
Maytag LAT5004AAW WASHER-TOP LOADING
Admiral LAT5004AGW WASHER-TOP LOADING
Admiral LAT5004BGW WASHER-TOP LOADING
Maytag LAT5005AAE WASHER-TOP LOADING
Maytag LAT5005AAW WASHER-TOP LOADING
Maytag LAT5005ABW WASHER-TOP LOADING
Maytag LAT5006AAE WASHER-TOP LOADING
Admiral LAT5006AGE WASHER-TOP LOADING
Admiral LAT5006GGE WASHER-TOP LOADING
Maytag LAT5910AAL WASHER-TOP LOADING
Maytag LAT5910AAW WASHER-TOP LOADING
Maytag LAT5910BAL WASHER-TOP LOADING
Maytag LAT5910BAW WASHER-TOP LOADING
Maytag LAT5914AAE WASHER-TOP LOADING
Maytag LAT5914AAL WASHER-TOP LOADING
Maytag LAT5914AAM WASHER-TOP LOADING
Maytag LAT5916AAE WASHER-TOP LOADING
Maytag LAT5916AAM WASHER-TOP LOADING
Maytag LAT5916ABE WASHER-TOP LOADING
Maytag LAT6910AAL WASHER-TOP LOADING
Maytag LAT6910AAW WASHER-TOP LOADING
Maytag LAT6914AAE WASHER-TOP LOADING
Maytag LAT6914AAL WASHER-TOP LOADING
Maytag LAT6914AAM WASHER-TOP LOADING
Maytag LAT7300AAL WASHER-TOP LOADING
Maytag LAT7300AAW WASHER-TOP LOADING
Maytag LAT7300ABL WASHER-TOP LOADING
Maytag LAT7300ABW WASHER-TOP LOADING
Maytag LAT7300ABX WASHER-TOP LOADING
Maytag LAT7300AGL WASHER-TOP LOADING
Maytag LAT7300AGW WASHER-TOP LOADING
Maytag LAT7300AGX WASHER-TOP LOADING
Maytag LAT7304AAE WASHER-TOP LOADING
Maytag LAT7304AAL WASHER-TOP LOADING
Maytag LAT7304AAM WASHER-TOP LOADING
Maytag LAT7304ABE WASHER-TOP LOADING
Maytag LAT7304ABL WASHER-TOP LOADING
Maytag LAT7304ABM WASHER-TOP LOADING
Admiral LAT7304AGE WASHER-TOP LOADING
Maytag LAT7304DAL WASHER-TOP LOADING
Maytag LAT7304EGE WASHER-TOP LOADING
Admiral LAT7304GGE WASHER-TOP LOADING
Maytag LAT7306AAE WASHER-TOP LOADING
Maytag LAT7314AAE WASHER-TOP LOADING
Maytag LAT7314AAL WASHER-TOP LOADING
Maytag LAT7314AAM WASHER-TOP LOADING
Maytag LAT7334AAE WASHER-TOP LOADING
Maytag LAT7334AAL WASHER-TOP LOADING
Maytag LAT7334AAM WASHER-TOP LOADING
Maytag LAT7334ABE WASHER-TOP LOADING
Maytag LAT7400AAL WASHER-TOP LOADING
Maytag LAT7400AAW WASHER-TOP LOADING
Maytag LAT7400ABL WASHER-TOP LOADING
Maytag LAT7400ABW WASHER-TOP LOADING
Maytag LAT7400ABX WASHER-TOP LOADING
Maytag LAT7480AAL WASHER-TOP LOADING
Maytag LAT7480AAW WASHER-TOP LOADING
Maytag LAT7480ABL WASHER-TOP LOADING
Maytag LAT7480ABW WASHER-TOP LOADING
Maytag LAT7500AAL WASHER-TOP LOADING
Maytag LAT7500AAW WASHER-TOP LOADING
Maytag LAT7500ABL WASHER-TOP LOADING
Maytag LAT7500ABW WASHER-TOP LOADING
Maytag LAT7500ABX WASHER-TOP LOADING
Maytag LAT7500AGL WASHER-TOP LOADING
Maytag LAT7500AGW WASHER-TOP LOADING
Maytag LAT7500AIL WASHER-TOP LOADING
Maytag LAT7500AIW WASHER-TOP LOADING
Maytag LAT7793AAL WASHER-TOP LOADING
Maytag LAT7793AAW WASHER-TOP LOADING
Maytag LAT7793ABL WASHER-TOP LOADING
Maytag LAT7793ABW WASHER-TOP LOADING
Maytag LAT7800AAL WASHER-TOP LOADING
Maytag LAT7800AAW WASHER-TOP LOADING
Maytag LAT7800ABL WASHER-TOP LOADING
Maytag LAT7800ABW WASHER-TOP LOADING
Maytag LAT7800ABX WASHER-TOP LOADING
Maytag LAT8004AAE WASHER-TOP LOADING
Maytag LAT8004AAL WASHER-TOP LOADING
Maytag LAT8004AAM WASHER-TOP LOADING
Maytag LAT8004ABE WASHER-TOP LOADING
Maytag LAT8005AAE WASHER-TOP LOADING
Maytag LAT8005AAM WASHER-TOP LOADING
Maytag LAT8006AAE WASHER-TOP LOADING
Maytag LAT8006AAM WASHER-TOP LOADING
Maytag LAT8014AAE WASHER-TOP LOADING
Maytag LAT8014AAL WASHER-TOP LOADING
Maytag LAT8014AAM WASHER-TOP LOADING
Maytag LAT8014ABE WASHER-TOP LOADING
Maytag LAT8016AAE WASHER-TOP LOADING
Maytag LAT8024AAE WASHER-TOP LOADING
Maytag LAT8024AAL WASHER-TOP LOADING
Maytag LAT8024AAM WASHER-TOP LOADING
Maytag LAT8026AAE WASHER-TOP LOADING
Maytag LAT8026AAM WASHER-TOP LOADING
Maytag LAT8026ABE WASHER-TOP LOADING
Maytag LAT8034AAE WASHER-TOP LOADING
Maytag LAT8034AAL WASHER-TOP LOADING
Maytag LAT8034AAM WASHER-TOP LOADING
Maytag LAT8035AAE WASHER-TOP LOADING
Maytag LAT8035AAM WASHER-TOP LOADING
Maytag LAT8100AAL WASHER-TOP LOADING
Maytag LAT8100AAW WASHER-TOP LOADING
Maytag LAT8100ABL WASHER-TOP LOADING
Maytag LAT8100ABW WASHER-TOP LOADING
Maytag LAT8104AAE WASHER-TOP LOADING
Maytag LAT8104AAL WASHER-TOP LOADING
Maytag LAT8104AAM WASHER-TOP LOADING
Maytag LAT8106AAE WASHER-TOP LOADING
Maytag LAT8106ABE WASHER-TOP LOADING
Maytag LAT8120AAL WASHER-TOP LOADING
Maytag LAT8120AAW WASHER-TOP LOADING
Maytag LAT8140AAL WASHER-TOP LOADING
  #2 (permalink)
Old 06-07-2010, 04:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Victor,
The advice:
Quote:
...to verify the hose running from the water switch to basket bottom-- it might be clogged or with leaky...
sounds correct in your situation.
You have to open the control panel and remove the front panel to inspect the air hose (#2 on the diagram). Make sure there is no water in the washer. Disconnect the hose from the water level switch (#13 on the diagram) and blow some air through it to make sure it goes through free.
Reconnect the air hose and run the washer. If the problem exists, replace the water level switch. Unfortunately Appliance Parts Pros does not ship parts outside US but may be you have someone in US who can order it for you and reship it to you.
- The water level switch Part number: AP4028437
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-08-2010, 01:59 PM
Junior Member
Smile Water switch test
Gene,
I blew into the water switch hose and it was clear all the way to the tub. Turned on the washer (after assembling everything..) and it stopped filling at super setting, but just barely overflowed. My guess is that the switch is defective and I ordred a new one. Thank you for your advice! Victor
  #4 (permalink)
Old 06-08-2010, 03:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Victor.
Make sure there is no water in the washer prior to replace the switch. Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef CAV2000AWW Top Load Washer overflows boggy golfer Washer Repair 3 09-18-2010 05:32 AM
washer spins slowly and doesn't drain large load kbarnitz Washer Repair 1 04-22-2010 06:13 PM
GE front load washer leaves fabric softener around large rubber ring at end of cycle jenlindquist Washer Repair 1 12-27-2009 12:36 PM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 03:49 AM
Washer leaks when large load selected dlk Washer Repair 1 02-22-2008 09:20 PM
