Discuss
Washer motor hums, but won't drain, agitate or spin
 in
Washer Repair
My washer suddenly stopped working. It still fills with water, but the motor doesn't work. It hums when I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer motor hums, but won't drain, agitate or spin
  #1 (permalink)
Old 09-10-2007, 02:55 PM
redwood646 redwood646 is offline
Junior Member
redwood646 is on a distinguished road
Default Washer motor hums, but won't drain, agitate or spin
Model Number: LSC8244BQ0   Brand: Whirlpool   Age: 5 - 10 years
My washer suddenly stopped working. It still fills with water, but the motor doesn't work. It hums when I close the lid, so I don't think the lid switch is the problem. I removed the motor and visually inspected it: I don't see any burns or broken wiring. Even when the motor is disconnected from the agitator and the pump, it won't spin and only hums.
What else can I check? I don't want to shell out $130 for a new motor just to find that wasn't really the problem.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-11-2007, 03:54 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You may have a bad pin on the motor connector, just push them in further.
If ok you will need a meter to check out timer and motor wiring.
__________________
  #3 (permalink)
Old 09-11-2007, 08:39 PM
Junior Member
Default
Thanks for the reply. I checked and the pins are all connected.
I found a diagram for testing the motors wiring here Direct drive washer motor repair information, how to test a direct drive motor with a meter Kenmore, Whirlpool, Inglis. And it checks out ok except for test E (white and white/black wires) with was infinity instead of 0.
However, I think I found the culprit. I checked the timer and one of the contacts is burnt like in this picture http://www.applianceaid.com/newpics/burnttimer2.JPG
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't spin or agitate BH5977 Washer Repair 3 11-03-2007 03:56 PM
GE Washer Tank Fills but No Spin/Wash/Drain jrgreulich Washer Repair 3 09-02-2007 06:09 PM
Maytag Washer just hums spurzem Washer Repair 0 08-22-2007 11:17 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 07:37 AM
Washer will spin slowly but not drain Mikie Martin Washer Repair 0 07-31-2007 08:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
