Discuss
Replacement motor has different wiring harness???
 in
Washer Repair
My washer doesn't seem to want to spin during the final cycle. The belt looked fine so I figured
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replacement motor has different wiring harness???
  #1 (permalink)
Old 07-16-2008, 05:58 PM
Tripleblack88 Tripleblack88 is offline
Junior Member
Tripleblack88 is on a distinguished road
Default Replacement motor has different wiring harness???
Model Number: WCSR2070T8WW   Brand: GE   Age: 5 - 10 years
My washer doesn't seem to want to spin during the final cycle. The belt looked fine so I figured it was the motor so I ordered one thru GE. The new one looks similar (they said that this the updated replacement part) BUT the wiring harness is different. The original plug in is flat and the new motor is square. The new motor came with another harness but the ends are just cut and bare.
I looked at the replacement motor on this site and its the same one GE sent. If you look at the picture, you will see a pic of the wiring harness.
My question is...do I have to re-wire this whole thing to replace the motor? There's got to be an better way???
Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-16-2008, 09:26 PM
Junior Member
Default
Well, I got the motor in, but it didn't fix the problem. It still does not go thru the spin cycle.
Any ideas? I think the only other major part is the "Transmission and Brake assembly". Could that be it?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wiring to motor misterfixall Dishwasher Repair 0 07-03-2008 03:41 PM
Blower Motor Wiring Question billnc Heating, Ventilation, and Air Conditioning (HVAC) 2 06-19-2008 08:06 PM
Wiring a Motor back into Maytag Dryer...HELP! thnkpink16 Dryer Repair 1 04-07-2008 03:17 PM
Whirlpool cooktop harness replacement midge Oven Repair (including Ranges and Cooktops) 0 02-25-2008 11:43 AM
Jennair Range Switch Harness Replacement zoblamouche Oven Repair (including Ranges and Cooktops) 0 11-22-2007 10:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
