Discuss
Roper washer Needs Help
 in
Washer Repair
When I turn on the washer to fill, it continues to fill until manually turning it off. You can wait
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer Needs Help
  #1 (permalink)
Old 07-16-2008, 04:52 PM
shane k shane k is offline
Junior Member
shane k is on a distinguished road
Exclamation Roper washer Needs Help
Model Number: RAX7245BWO   Brand: Roper   Age: More than 10 years
When I turn on the washer to fill, it continues to fill until manually turning it off. You can wait a few mintues and turn the washer on again and it will begin washing. It will continue through the cycles without issues. Only issues are when filling washer. I replaced the water level switch as suggested by my "washer repair friend". It is like the switch is not getting enough pressure to allow the machine to stop the fill cycle and begin washing. What do you think the problem may be?
Related Models
Whirlpool RAX7245JQ0
Whirlpool RAX7245KQ0
Whirlpool RAX7245KQ1 Automatic Washer
Whirlpool RB1000XKW0
Whirlpool RB1000XKW1
Whirlpool RB1000XKW2
Whirlpool RB1000XVN0
Whirlpool RB1000XVN2
Whirlpool RB1000XVN3
Whirlpool RB1000XVW0
Whirlpool RB1000XVW2
Whirlpool RB1000XVW3
Whirlpool RB1005XYN0
Whirlpool RB1005XYN2
Whirlpool RB1005XYN3
Whirlpool RB1005XYN5
Whirlpool RB1005XYW0
Whirlpool RB1005XYW2
Whirlpool RB1005XYW3
Whirlpool RB1005XYW5
Whirlpool RB100PXK0
Whirlpool RB100PXK1
Whirlpool RB100PXK2
Whirlpool RB100PXV0
Whirlpool RB100PXV2
Whirlpool RB100PXV3
Whirlpool RB100PXYB0
Whirlpool RB100PXYB2
Whirlpool RB100PXYB3
Whirlpool RB100PXYB5
Whirlpool RB1200XKW0
Whirlpool RB1200XKW1
Whirlpool RB1200XKW2
Whirlpool RB1200XVN0
Whirlpool RB1200XVN2
Whirlpool RB1200XVW0
Whirlpool RB1200XVW2
Whirlpool RB120PXK0
Whirlpool RB120PXK1
Whirlpool RB120PXK2
Whirlpool RB120PXV0
Whirlpool RB120PXV1
Whirlpool RB120PXV2
Whirlpool RB120PXV3
Whirlpool RB120PXYB0
Whirlpool RB120PXYB2
Whirlpool RB120PXYB3
Whirlpool RB120PXYB5
Whirlpool RB1300XKW0
Whirlpool RB1300XKW1
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0
Whirlpool RB130PXK1
Whirlpool RB130PXK2
Whirlpool RB130PXK3
Whirlpool RB130PXV0
Whirlpool RB130PXV1
Whirlpool RB130PXV3
Whirlpool RB130PXV4
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
Frigidaire RB131CF0 Frg(v2) / Electric Cooktop
Frigidaire RB131CF1 Frg(v2) / Built - in Electric Cooktop
Frigidaire RB131CH0 Frg(v3) / Electric Cooktop
Frigidaire RB131CH1 Frg(v3) / Built - in Electric Cooktop
Frigidaire RB131CL0 Frg(v4) / Electric Cooktop
Frigidaire RB131CL1 Frg(v4) / Built - in Electric Cooktop
Frigidaire RB131CM0 Frg(v5) / Electric Cooktop
Frigidaire RB131CM1 Frg(v5) / Built - in Electric Cooktop
Frigidaire RB131CW0 Frg(v6) / Electric Cooktop
Frigidaire RB131CW1 Frg(v6) / Built - in Electric Cooktop
Frigidaire RB131NL1 Frg(v2) / Electric Range
Frigidaire RB131NL2 Frg(v3) / Electric Cooktop Range
Frigidaire RB131NL3 Frg(v6) / Electric Cooktop Range
Frigidaire RB131NM1 Frg(v3) / Electric Range
Frigidaire RB131NM2 Frg(v1) / Electric Cooktop Range
Frigidaire RB131NM3 Frg(v4) / Electric Cooktop Range
Frigidaire RB131NW1 Frg(v1) / Electric Range
Frigidaire RB131NW2 Frg(v2) / Electric Cooktop Range
Frigidaire RB131NW3 Frg(v5) / Electric Cooktop Range
Frigidaire RB136CDB0 Frg(v1) / Electric Range
Frigidaire RB136CL1 Frg(v1) / Electric Cooktop
Frigidaire RB136CL2 Frg(v1) / Electric Cooktop
Magic Chef RB150ALM Ref - Top Mount
Magic Chef RB150ALV Ref - Top Mount
Magic Chef RB150AM Ref - Top Mount
Magic Chef RB150AV Ref - Top Mount
Magic Chef RB150PA Ref - Top Mount
Magic Chef RB150PLA Ref - Top Mount
Magic Chef RB150PLW Ref - Top Mount
Magic Chef RB150PW Ref - Top Mount
Magic Chef RB150RA Ref - Top Mount
Magic Chef RB150RLA Ref - Top Mount
Magic Chef RB150RLW Ref - Top Mount
Magic Chef RB150RW Ref - Top Mount
Magic Chef RB150TA Ref - Top Mount
Magic Chef RB150TLA Ref - Top Mount
  #2 (permalink)
Old 07-16-2008, 04:57 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Chances are it is the hose that is connected to the tub that connects to the pressure switch. You will need to get access to the tub, and remove the pressure switch hose, look in it and see if you can see it plugged up. Go ahead and cut off the clogged part and see what happens.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper washer snallac Washer Repair 2 11-20-2009 04:08 AM
roper washer muttavous Washer Repair 2 03-07-2009 06:57 PM
roper washer michelle whelan Washer Repair 2 02-24-2009 03:41 PM
Roper Washer Not Draining julieann Oven Repair (including Ranges and Cooktops) 2 11-26-2008 06:21 AM
roper washer question whitehanes34 Washer Repair 2 12-02-2007 12:03 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
