| » Roper washer Needs Help |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: RAX7245BWO Brand: Roper Age: More than 10 years
When I turn on the washer to fill, it continues to fill until manually turning it off. You can wait a few mintues and turn the washer on again and it will begin washing. It will continue through the cycles without issues. Only issues are when filling washer. I replaced the water level switch as suggested by my "washer repair friend". It is like the switch is not getting enough pressure to allow the machine to stop the fill cycle and begin washing. What do you think the problem may be?
Chances are it is the hose that is connected to the tub that connects to the pressure switch. You will need to get access to the tub, and remove the pressure switch hose, look in it and see if you can see it plugged up. Go ahead and cut off the clogged part and see what happens.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| Roper Washer Leaks | Lynn744 | Washer Repair | 0 | 04-17-2008 09:06 AM |
| Roper washer won't spin | cheapster | Washer Repair | 3 | 03-15-2008 10:22 PM |
| Roper washer will not drain | maximum destruction | Washer Repair | 4 | 01-07-2008 03:46 PM |
| roper washer question | whitehanes34 | Washer Repair | 2 | 12-02-2007 12:03 PM |
| Roper washer will not spin | rodtamara | Washer Repair | 0 | 11-12-2007 03:35 PM |
