| » Washer not pumping at the end of wash but will pump on spin and lite wash. |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: WWSE4200A0WW Brand: GE Age: 5 - 10 years
Hello,
Mom's washer is displaying symptoms of what I think is either a control assembly, or pressure switch issue. I have plenty of DVM's. rathboneenergy.com The washer fills, runs the wash cycle, it is then supposed to pump but does not, it clicks. You can turn the switch to spin and it will pump out the water and you continue. You can wash on the lite cycle and it will pump at the end of each cycle properly. Now, the lite cycle and the spin cycles are beginning to clink but they are still pumping. I know I can go in and check continuity put am looking to save time through the prior experience of others. Thank you, Ron |
| Display Modes | |
| Washer wont wash or spin out | alishacranston | Washer Repair | 1 | 05-29-2008 02:30 PM |
| washer will not drain or spin after wash cycle | water | Washer Repair | 1 | 05-29-2008 02:25 PM |
| Washer fills , won't wash sometimes,spin Ok | jgreen | Washer Repair | 0 | 03-13-2008 07:30 PM |
| My washer will wash but not rinse or spin. | artistedesign | Washer Repair | 3 | 02-15-2008 12:28 PM |
| Washer will fill and wash, but not spin and empty | cwp | Washer Repair | 0 | 11-06-2007 09:22 AM |
