Discuss
Washer not pumping at the end of wash but will pump on spin and lite wash.
 in
Washer Repair
Hello, Mom's washer is displaying symptoms of what I think is either a control assembly, or pressure switch issue.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer not pumping at the end of wash but will pump on spin and lite wash.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-16-2008, 11:45 AM
rathbonr rathbonr is offline
Junior Member
rathbonr is on a distinguished road
Default Washer not pumping at the end of wash but will pump on spin and lite wash.
Model Number: WWSE4200A0WW   Brand: GE   Age: 5 - 10 years
Hello,
I have plenty of DVM's. rathboneenergy.com
The washer fills, runs the wash cycle, it is then supposed to pump but does not, it clicks. You can turn the switch to spin and it will pump out the water and you continue. You can wash on the lite cycle and it will pump at the end of each cycle properly.
Now, the lite cycle and the spin cycles are beginning to clink but they are still pumping.
I know I can go in and check continuity put am looking to save time through the prior experience of others.
Thank you,
Ron
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer wont wash or spin out alishacranston Washer Repair 1 05-29-2008 02:30 PM
washer will not drain or spin after wash cycle water Washer Repair 1 05-29-2008 02:25 PM
Washer fills , won't wash sometimes,spin Ok jgreen Washer Repair 0 03-13-2008 07:30 PM
My washer will wash but not rinse or spin. artistedesign Washer Repair 3 02-15-2008 12:28 PM
Washer will fill and wash, but not spin and empty cwp Washer Repair 0 11-06-2007 09:22 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
