Discuss
Maytag MAH5500B Door will not latch
 in
Washer Repair
When we tried to runn a load of clothes, the washer ran long enough to get the clothes slightly wet
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag MAH5500B Door will not latch
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-15-2008, 07:38 PM
ronstr ronstr is offline
Junior Member
ronstr is on a distinguished road
Default Maytag MAH5500B Door will not latch
Model Number: MAH5500BWQ   Brand: Maytag   Age: 5 - 10 years
When we tried to runn a load of clothes, the washer ran long enough to get the clothes slightly wet and then stopped. The display showed an error message of FL. Now if we try to run it, the washer just sits there for a few minutes and then displays the same error. Could it be the door latch? A couple of years ago, we had some parts replaced under the class action suit. I found the old door latch that was replaced and it reads EMZ with a Maytag part number on it-62722120 and an EMZ part number-38.0150. Is it possible that replacing the door latch assembly would fix it, or is it something else?
Ron
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-16-2008, 07:42 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Ron,
Open the control panel and look for the tech sheet inside. It should have the explanation for the error codes and troubleshooting guide.
Here are the break down diagrams for the Maytag Neptune washer Model MAH5500BWQ
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
door latch. 123dpw Microwave Repair 7 02-06-2008 05:14 AM
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 2 12-28-2007 11:42 AM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 10:40 AM
Door latch broken/Door locked kitade Dishwasher Repair 2 10-23-2007 10:42 AM
Maytag Front loader door latch assembly bpcolll Washer Repair 4 08-29-2007 09:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
