I have replaced the lid switch. Agitation stops when lid is opened, starts when lid is closed.
Washer fills and agitates but will not drain or spin. Timer moves from wash to off but tub remains full.
It agitates on wash, moves to rinse and agitates again, moves to wash.
Does the motor make any noise when it should spin? If it does not, remove the front panel and check all wires from the timer to the motor. Check the motor according to the wiring diagram. If there is nothing wrong, replace the timer. - The timer Part number: AP4027897
Originally Posted by: Gene Does the motor make any noise when it should spin? If it does not, remove the front panel and check all wires from the timer to the motor. Check the motor according to the wiring diagram. If there is nothing wrong, replace the timer. - The timer Part number: AP4027897
Thanks for the help, the new timer solved the problem. Layne
