Discuss
oil in center post??
 in
Washer Repair
I'm replacing the transmission and since there was some oil in the center post (the clutch drive tube slides
Appliance Repair Forum > Appliance Repair Help > Washer Repair » oil in center post??
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-15-2008, 12:08 PM
wedrons wedrons is offline
Junior Member
wedrons is on a distinguished road
Question oil in center post??
Model Number: 110.28894790   Brand: Kenmore   Age: 5 - 10 years
I'm replacing the transmission and since there was some oil in the center post (the clutch drive tube slides through it) what type and weight of lube should I put in it and how much?
Thanks,
wedrons
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-16-2008, 02:42 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I use light turbine oil, non-detergent available in a squeeze tube from most appliance parts suppliers.
Also, I put some silicone grease under the upper spindle seal. I never pull the spin tube out all the way, never necessary. Make sure you clean off all rust areas on the tranny spindle before installing.
__________________
  #3 (permalink)
Old 07-16-2008, 06:32 PM
Junior Member
Default
Thanks Rich,
Going to use 20ND since the closest appliance store is 130m rt. How far up the tube do u fill it?
Skip
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice not solid in the center turnkey Refrigerator & Freezer Repair 0 04-16-2008 09:38 AM
Refrigerator center frame too hot. BEEJAY Refrigerator & Freezer Repair 1 02-19-2008 03:15 PM
wash tub off center daveperk Washer Repair 1 01-24-2008 11:21 AM
addition to earlier post deano49 Refrigerator & Freezer Repair 0 08-20-2007 10:59 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
