| » GE Top load washer will not spin/drain :-( |
Model Number: wcsr4170daww Brand: GE Age: 1 - 5 years
Hello,
My GE washer (model number WCSR4170DAWW) stopped spinning and draining on me yesterday Ads By Google Related Models |
Last night, I compiled a list of “tests” that I read on the site and ordered them from the easiest (blowing into the drain pipe) to the most difficult (running continuity tests on the power to the pump and motor). Well, to my surprise, I blew into the drain and the air was obviously restricted! I took the pump apart to find one of my daughter’s socks stuck in it. That caused the machine to not drain OR spin. Everything is working perfectly again.
My name is Mark & I'm also a service tech, with GE experience. What I have found is, when one of these style washers is over loaded, it is very easy for a small item (like a kids sock) to spin up and over the tub, falling down into the tub. Then the item will eventually clog the drain hose into the pump or be sucked into the pump and jamb the pumps impeller. If left unchecked for a few hours, it will burn out the pumps motor. This is a very common issue in the old Maytag top loaders (mainly the commercial ones when over loaded). How ever it rarely ever damaged a poly pump, the belt would just slip until it smoked! Ha Ha!! I hope this post helps solve- "the old sock in the pump mystery." or at least how it got in there! |
| Display Modes | |
| GE Front Load Washer Won't Drain | scottbreen | Washer Repair | 36 | Yesterday 05:39 PM |
| Front load washer will not rinse/drain or spin out | haroldlm | Washer Repair | 2 | 12-11-2009 06:08 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| front load drain/spin problem | tammyclif | Washer Repair | 5 | 07-25-2009 01:06 PM |
| front load washer is not drain and spin | keithzhao | Washer Repair | 9 | 12-04-2008 07:27 AM |
