Discuss
Selection Knob Won't Catch and Turn
 in
Washer Repair
I have a GE Hotpoint washer. The knob to the right that you press in and turn to select what
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Selection Knob Won't Catch and Turn
  #1 (permalink)
Old 07-15-2008, 09:44 AM
Junior Member
Foneswood is on a distinguished road
Default Selection Knob Won't Catch and Turn
Model Number: ZZXR1040T2WB   Brand: GE   Age: More than 10 years
I have a GE Hotpoint washer. The knob to the right that you press in and turn to select what type of water temperature you want isn't working correctly. Usually you press it in and turn it to the correct temperature and it would click as you turn it. Now it acts like something is worm because it will "bump" along when you try to turn it and eventually it will "catch" so you can turn it to the correct water temperature. Is it just the knob or some part behind the knob I can't see.
  #2 (permalink)
Old 11-04-2009, 12:46 PM
Junior Member
RBG1 is on a distinguished road
Default
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cycle Selection Knob Not Turning donnamcleese Washer Repair 1 11-10-2009 04:45 PM
Cycle Selection Knob cleanclothes Dishwasher Repair 0 10-10-2009 09:43 AM
GE Washer cycle selection knob midlander Washer Repair 1 09-23-2009 10:06 AM
cooktop knob won't turn taterboy Oven Repair (including Ranges and Cooktops) 1 03-02-2009 11:29 AM
